how do you tune a port
  • 3
spencerS
I'm getting a triple x 12 or 15. Im going to build a box for it, as big as the space in my honda civic coupe trunk will allow. how do I tune the port? Where do I put it?how long does it have to be? and how do you arrive at these numbers? Is there an equation to go by. MAHALO for the feedback
a good starting place is around 28-35 hz. that'll give a good combination of sq and spl....
u could down load winISD to help build ur box....if someone has a link, could ya post it, otherwise i'll look for it and get it here.
not only what jmac said, but if u have the t/s parameters for ur sub, u can input them manually in winISD.
good luck with the box!
personally I would email RE because I emailed adire and they gave me all the stuff I needed. They also said that power has something to do with it too.
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
789
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
969
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
944
spencerS
spencerS
waimanalo HI
85ss
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
