How good is Alpine?
  • Thread starter <SkMexiFry>
  • Start date
  • Replies 2
  • Views 2K
  • 1
<SkMexiFry>
Guest
I need some feedback on Alpine S series 12". Is about 400 watts rms good for them? They have a 600 watt peak. Please recommend what type of enclosure i should use as well. Thanks!
Another Question: Does fiberfill make a big bass difference?
They are decent subs for the cash. Probably would be a little better to spend the extra couple of bucks and move up to the type-R however.
The Type S 12 should have the following enclosure requirements.
Sealed:1.5ft^3
Ported:2.0-2.5ft^3
The power you have will work well.
Fiber-fill/poly fill generally does not create much of an audible difference. It is basically used to slow the soundwaves down a little to make it seem as if the sub is in a larger enclosure.
Take it easy,
-zane
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
110
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
362
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Guest
zane
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
