MTX Thunder 6000
  • Thread starter <zac77>
  • Start date
  • Replies 3
  • Views 2K
  • 2
Well I am a owner of a 10" MTX 6000 series. Ive blowen the voice coil already and am on my second one. If I would replace this one with yet another one, I would say no. The 12's are nice, but there are alot of excellent subs out there on the market. RF's you may even find cheaper than the MTX's, and sound quality is better. Good luck!
I run 6 8000 series 12"s for competition and I was impressed. Never settle for a step below..never. You will be happier with the 8000's. They sound cleaner and will not distort at higher levels of volume. **** crutch field........over priced bastards. Look on-line I found my subs for less then $160 each.
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
4
744
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
5
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
5
Guest
Puff the dragon
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
