How loud is your system?
Do you guys think I'd see a big difference if I moved my batteries and amps to the way back and slid my box forward 10 inches?
Have you metered it outlaw style? Does it gain quite a bit door open?
I gain about 2 db when I open a door. Haven't tried a window. I definitely can hear and feel the difference. And I like to listen to the music with the sunroof open or a window open cuz I can feel more airflow
hitting at 25 - 35 hz,
What sort of music do you use where you need to play so low?
Numbers seem a bit shy of where you could be with that but the box seems to play rather flat and probably sounds good with music.
If your goal is to play lower you must rebuild your port or box to tune lower. You may or may not be happy with the rest of your frequency response after you do so.
Try going into your settings and look for system sounds. You may be able to adjust it there. Or, you can go into your phone settings, look for...
LMAO.yep,this setup going on over 9 years.appreciate the inspirational quote although i dont take part in water boy memes.
10
Welcome to the forum. I hope things go well for you. We like good products made in the USA. I'm cool with paying more to get that.
4
No rc bug yet? I got bit bad and left audio for years doin rc again.
22
5K
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
11
Deon1818
Deon1818
MN
Slo_Ride
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
