How many batteries for this set up?
  • 2
lilsullivan04
Hi,
I was wanting to know how many batteries would I need for this set-up. I'm planning on getting a DC Power 320 amp SPX-i high output alternator. And for the sound system I will have a total of 7, 000 watts rms I will be changing out my stock battery.
I was thinking of going with XS Power batteries. The XS 4800D will fit in my stock location. What addition battery or batteries do I need and how do I wire them?
I have a 2011 GMC Sierra and it has the extra battery tray and I could put an extra battery there. Would I need more than two batteries?
How much of your 7kw total will be sub amp(s)? Personally I wouldn't spend money on xs batts. I've done a few builds with them for other people and they do nothing more then my dekas other, then make your wallet a lot lighter....
4 G31 Dekas is what I'd do. SuperStart+, NGT Extreme, Duracell at Sam's club, all the same batt...
You wire them all in parallel. I'd do 2 POS runs of 1/0 from front to rear batts. 2 NEG runs in back. Fuse POS runs at BOTH ends.
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
4K
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
11
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
4
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
lilsullivan04
lilsullivan04
Kansas City, MO
lilsullivan04
