How many Hz?
HT = Home Theater
Meaning for home use in a home sound system, not a car.
I would also go for 30-34hz tuning, definitely not 21..
Head over to a box calculator like RE's box calc. or the12volt's or one of the other ones and play around there.
srry... im an idiot..but i no it needs 3.5ft^3.....but what bout width of the port..and is the volume of the port in with the 3.5?...srry again..nvr done ne a this be4
i think ive figured it out on res box calculator...u say in need to tune it to 32hz
i have made this way more complicated than it acually is
you will be fine tuned to 30hz //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
you dont need a huge box with that sub
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
4K
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
11
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
4
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
mccoy
mccoy
pikeville, ky
Slammed
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
