How many litres subwoofer ported box ?
  • 2
Drifter mike
CarAudio.com Recruit
32
Greece
Hello guys,
I want to buy this sub for my car (Mercedes A 140 W168):
MODEL: TRF VLSW123D2
IMPEDANCE: Dual 2 ohm
CONE:competition grade paper
SURROUND MATERIAL:foam
VOICE COIL:2 inch
RMS POWER:350 WATT
SENSITIVITY:89.2db
MAX WATT:700wmaxx
RESORANCE FREQUENCY(fo):36.2Hz
MECHANICAL Q FACTOR(Qms):5.6
ELECTRICAL Q FACTOR(Qes):0.62
TOTAL Q FACTOR(Qts):0.56
X MAX:6 mm
FORCE FACTOR:13.6 N/A
MAGNET WEIGHT:50 oz
How many litres ported box do you think i will need in order for the sub to perform its best ?
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
4K
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
11
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
4
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
Drifter mike
Drifter mike
Greece
Drifter mike
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
