How should I hook all of this stuff up?
  • 2
CheapPyramidStuff
I have a list of equipment at the bottom of the message which you guys might laugh at, but actually works really well. I have 2 4's, 2 6x9's, and 1 sub in a bandpass installed right now. I plan on putting the tweets up front, keep the 4's in the stock location in the dash, JBL 6x9's in my front doors, other 4's in my rear doors, and 6x9's in the rear deck. I have a 85 Toyota Camry. Also, is there a good design for a 3 sub bandpass that works well? I really like the performance of my sub in a bandpass box. Thanks.
Welcome to the forum!!
Sounds like you are the one brainstorming the perfect low buck system here!
While I normally would not reccomend pyramid, lets work with what you have.
I can firstly say that it is safe to omit half the speakers from your install and obtain even better soundstage.
The rear door speakers and the rear deck speakers can go. In a properly tuned system, there should be no need for them. Plus, I will stake vital parts of my anatomy that the 4's in the rear doors will not be heard that well either way.
A side note, you are aware that the 6x9's going in the front doors will likely require modification to the doors sheet metal and door panel to properly fit. Unless you build out your doors, your 6x9's will probably not clear the path of the window and locking mechanisms.
On that note, I have likely placed a few thoughts into your head, so i will let you think on them and if you have any other questions, please dont hesitate to ask.
As for the bandpass, I believe that Orion does build a pre-fab triple bandpass enclosure, however, What specifically interests you in the bandpass design?
Ok, done twisting your arm......
(for now!
Take it easy,
-zane
The CT's are nice, That Sundown is a a frik'n beast!
7
574
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
521
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
616
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
8
930
CheapPyramidStuff
CheapPyramidStuff
Kamloops BC Canada
zane
SlugButter
    May 4, 2024
slater
    May 2, 2024
Latest topics
