How should I wire my doors
  • 3
JoshGuy
get the 2ohm set to get the most out of your amp as for wiring it one channel/wire will go into each x-over and then the tweeter and mid wire off that splitting the freq between the two.
so i should run my tweets on one channel and my mids on the other right?
Each amp channel wires to the crossover inputs and the crossover has outputs for tweeter and mid. Pretty simple.
Okay I got that but is there any way i can wire my doors in parallel so I could get 2 ohms on each channel?
Only if you have 2 sets per door. Or get a 2 ohm version if there is one.
Yeah they make a 2 ohm version and ill only have a set of components per door so how would i be able to wire 4 sets 2 ohm components to 2 ohm per channel
Just 4 doors so 4 tweets and 4 mids
OH that makes more sense I run a 2ch amp but I only run front comps, you may want to think about getting a 4ch amp instead or you will lose fade control also you would want the 4ohm speakers to obtain the 2ohm load per ch if you still want to go that route simply run the speakers as normal the only difference will be two sets of wires going into each ch instead of one set.
that wouldnt yield 8 ohms per channel? And on more thing would the component as a whole be rated at 4 ohms or 2 ohms per mid and then 2 ohms per tweeter?
You can't. If you're running 2 sets per channel they should be 4 ohms each. Two 4 ohm sets in parallel will be 2 ohms.
So I should get the 4 ohm version and wire them in parallel to get a 2 ohm outcome per channel. But how would that work with the crossovers?
It’s nice having a test bench. That one is nice and clean! I don’t have pics of mine but mine is built all out of wood with carpet top and all...
16
The CT's are nice, That Sundown is a a frik'n beast!
7
714
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
630
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
717
JoshGuy
JoshGuy
Lawton, OK
maylar
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
