How should I wire this sub?
Sedition
So I just ordered this amp from amazon: Amazon.com: Lanzar HTG257 2000 Watt 2-Channel Mosfet Amplifier: Electronics
and this sub: Amazon.com: Boss P12DVC 12" Subwoofer Dual 4ohm Voice Coils: Electronics
However, I got the sub and I have no idea how to wire it or what I should do to wire it. It looks like on the connectors on both sides on the back of the sub, there are 2 plugs for positive and 2 for negative on each side (a total of eight).
It's a Dual Voice Coil 4 ohm but I'm unsure how I should wire it and how to wire it to get the most from that amp.
Could someone please walk me through how to connect this the proper way and how I should run it from that amp?
Thanks,
Dylan
if your sub is dual 4 ohm..............wire + to + and - to - for a 2 ohm load..........hook the + coming from the sub into the + side of the amp and same for - add power ground and signal to your amp and let her sing //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Man I would honestly return that stuff and research it some. Both of those products are fairly low quality. I know people that can hook you up with some better deals.
I will holler if I am ever looking for something better. But going to this from a 300 watt Sony xplod and 350-watt DUAL amp I think it will be a pretty decent upgrade; for me at least. I don't need much!
Thank you! That's all I needed to know!
If you ever need help man just PM me.
It’s nice having a test bench. That one is nice and clean! I don’t have pics of mine but mine is built all out of wood with carpet top and all...
16
The CT's are nice, That Sundown is a a frik'n beast!
962
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
781
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
923
Sedition
Sedition
Brentwood, TN
Sedition
