How to download Halloween videos from YouTube?
  • 1
hekcik129
London
Jenny>
It is that time of year again, the exciting Halloween! Since activities in these days are wonderful, unforgettable, impressive, crazy, and fantastic, lots of them are recorded in the form of videos and uploaded to YouTube for sharing with all the people worldwide. Do you fall in love with some interesting, meaningful and unique video files about Halloween, and want to download them as your own collections so as to enjoy them in the leisure time? If so, this thread will definitely do you a favor, for it will instruct you how to download Halloween videos from YouTube in detail.
The software we will use here is Pavtube YouTube Converter, which is free for downloading, if you want to convert the downloaded FLV YouTube Halloween videos to other formats, you should use its retail version, if not, there will be watermarks of Pavtube stamped in the output files.
Okay, now let’s begin.
1. Download Pavtube YouTube Converter, install and run it.
2. Add URL, select output format
After launching, press “Add URL” in the main interface of this program, and then the following interface will pop up. Copy and paste URL of the Halloween videos which you want to download from YouTube into the textbox after “URL”. If you only want to use its downloading function totally for free, you should check “Only Download FLV source file”, and uncheck “Keep FLV source file”, on the contrary, if you want to convert it to other format while downloading as well as keeping the FLV source file, you should tick the checkbox of “Keep FLV source file” in advance.
Imagine you’d like to do downloading and converting work simultaneously, in that case, you should click on the drop-down list of “Convert to” to select an output format, here I choose “iPhone MPEG-4 640X480(*.MP4)” as an example.
Also, there are two more optional steps, namely, specify output file name and save path. Factually, this program will generate a file name and destination folder by default automatically, if you don’t like using these ones, you can type your preferred file name into the textbox after “Save as” and click on the ellipsis icon at the opposite side of “Save to” to specify a path to store the output files.
3. Custom
This program allows users adjusting video and audio parameters like codec, aspect ratio, bit rate, frame rate, etc. You can configure all of these items according to your own requirements. For instance, if you need change the output files to have a smaller size, and do not mind the output quality, you can adjust these parameters into smaller figures.
4. Click “OK” to start downloading and converting
Once all the above settings are done, you can now click “OK” button to begin downloading and converting your favorite Halloween videos from YouTube at the same time. Pavtube YouTube Converter will finish its tasks, even batch tasks at speed, and never let video and audio go in separate ways.
Well, just 4 simple steps, the downloading and converting work are completed, sincerely hope this guide is helpful for you to download or convert your beloved Halloween video files from YouTube.
By the way, I know an amused website specially designed for Halloween, it provides people with games and Halloween gifts, from which you can not only gain funs, but also get cute presents, play this game here, and happy Halloween.
Get more related articles here : Pavtube Halloween
Do you have a CD player connected to your Head unit? If so, does it add more voltage drop or use more power that's noticeable? No overheating...
hekcik129
hekcik129
London
hekcik129
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
