How to keep amps cooler?
12v fans just wire with a relay? Where can I buy those?
EDIT: Everything is set properly, gains far from clipping and my rear seat doesn't even have a blow through armrest let alone a fold down seat.
i have a water mister. it sprays water every 15 mins or so. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I just hose 'em down every morning before I leave...//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
The squirrel cage fans tend to move more air & give you some atypical mounting options.
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
317
You can pull that amplifier and take to an Audio shop and see if they will test it. Most shops charge very little and some will not even charge...
8
Go 150 Watts speakers or equal to your amps. 150 watts and up is your amps. That's the good rule of thumb.
12
The best thing you can do is make a solid plan. This way you won't be spending money twice and having to keep going back in add or replace parts.
27
4K
the727kid
the727kid
St. Pete, FL
watcher6342
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
