How to play camcorder videos MTS or M2TS files in Windows Media Player?
  • 1
With more and more camcorder products overflowing in our digital life, I guess you must shot some interesting or nice recordings in your Sony, JVC, Canon or Panasonic like me and often you may want to play them on your Windows Media Player or other media devices.
However, when you directly import the MTS or M2TS files into your windows media player you may find a big issue that this kind of player can not player MTS or M2TS files from AVCHD camcorders, for window media player can only accept WMV format. In other words, if you want to play or enjoy MTS or M2TS files on windows media player, you have to convert them to WMP format.
The following tutorial will show you the detailed information about how to convert MTS or M2TS files to WMV with this kind of tool called Moyea MTS/M2TS Converter I am using now.
Preparation: Free download Moyea MTS/M2TS Converter here, install and run it.
Step 1: Add MTS/M2TS files into this program
Step 2: Set the output format as WMV
Once all the files are imported, you can select the output format as WMV from the drop-down list “Format” as well as set the destination folder form the “Output” if you don’t want to save the output files in the default folder automatically.
Step 3: Set advanced settings
Click the “Convert” button, you can start converting and the generated files will be saved in your destination folder.
Step 4: Put the converted WMP files into your windows media player
See, the whole procedures will be done in a little time. I must say this kind of MTS/M2TS Converter is really a good helper for our HD camcorder users in certain aspect.
Try going into your settings and look for system sounds. You may be able to adjust it there. Or, you can go into your phone settings, look for...
Don't recall off hand. Both single dins. One excelon, one not.
968
I pulled an android unit out for a Heigh10. Regret the hell outta that. Android unit is SOLIDLY mounted. Heigh10...not so much. Bounces more than...
zsvrsn3
Banned
zsvrsn3
3636 Gateway Center, San Diego, Canada
zsvrsn3
Decebal
    Jun 10, 2024
