How to rip Blu-ray disks to the format of MKV?
  • 1
hekcik129
London
The popular trend of Blu-ray discs is irresistible, and lots of movies lovers are having Blu-ray collections more or less. At the same time, how to treasure these disks in a safer way without scratching, or how to enjoy them via many other media players or portable devices have become actual problems. Against this background, numerous Blu-ray rippers are designed for backup people’s favorite Blu-ray movies, and most of these rippers are available for directly coping without any loss or ripping Blu-rays to some other media formats with much smaller file size. Pavtube Blu-ray Ripper is such an application among them, which performs very well and does not have audio and video out of sync issues.  Since a large number of BD owners are asking about how to rip Blu-ray disks to the format of MKV, this post here will focus on this question, and give a solution to it via the help of Pavtube Blu-ray Ripper.
Step 1: Download, install and run Pavtube Blu-ray Ripper
After launched it, you will see the following interface at once. There are three ways provided to import Blu-ray files, namely through clicking on “DVD Rom”, “DVD Folder”, and “IFO/ISO”.
Step 2: Select MKV as output format, and set save path
Once Blu-ray files are loaded into this program, next you should click on the drop-down list of “Format” to select MKV as the output format. Notice that there are two kinds of MKV format, standard MKV and high definition MKV. To choose standard one, hit “Common Video” firstly and then left-click on “MKV (Matrosca) Video”. To choose HD MKV, click “HD Video” at first and then select “MKV HD Video”. Here I take SD MKV for example.
Meanwhile, this ripper enables you to join all the loaded Blu-ray files together as one file, just tick checkbox “Merge into one file” to achieve this goal. Also, you can click on the folder icon at the end of “Output” to specify a destination folder, if not, this program will export the generated MKV files to a save path set by default automatically.
Step 3: Set advanced settings
If you want to make good control of the output MKV file size and quality, you can click on “Settings” button to adjust video and audio parameters like codec, aspect ratio, bit rate, frame rate, sample rate, etc. In principle, the larger input values, the better image quality, but with enlarged output file size. On the contrary, the smaller input figures, the more inferior image quality, but with decreased file size. That means you should make a balance between file size and quality. If you are not good at this procedure, just skip this step.
Step 4: Start ripping
As soon as all the above mentioned steps are completed, what you should do next is pressing “Convert” button. After that, an interface as below will show up. Then you need hit “Start” button to begin Blu-ray ripping. You see, all the related ripping info are all showing clearly, including ripping progress, elapsed ripping time, left ripping time, generated file size and estimated file size, in that way, you can manage your time and HD space of your computer in a proper way. After ripping work is completed, you can press “Open” button to find out the output MKV files with ease, and then do whatever you like at will.
We lost a good guy today. RIP Jimmy Buffet. Everybody should play some Buffet today in honor of a great man...
  • Locked
https://www.caraudio.com/threads/classified-rules.481818/
hekcik129
hekcik129
London
hekcik129
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
