How to wire 2 JL 12w3 (4ohm) to jl 500/1 amp
  • 2
Correct, use option 2. You don't need to use both of the amps terminals.
If you were to use both terminals at the amp, you would still wire them in series (just separately, not together). As the terminals are connected in parallel inside the amp.
Is the big 3 upgrade necessary for a setup like this?
I have everything wired but the subs only hit for about 10-20 seconds at a time and then they'll go off for about 30 and come back on. I've never had to do the big 3 but I've never had an amp that was rated this high.
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
5
383
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
871
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
992
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
994
atown
atown
Taylorsville, UT
atown
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
