How to wire a dual 4 ohm voice coil sub to get a 2 ohm load?
  • 3
hogger
Murray, KY
Ive got a pair of 12" Jl Audio W3 dual voice coile 4 ohm speakers. I lost the sheet that came with them and was curious. How would I wire them to get a 2 ohm load. I think I am going to get a power 550s which gives an RMS of 275x2 at 2 ohms. A little diagram or something would be greatly appreciated!! Thank!!!
Whoa?! Now Ive got even more confused....the amp I am getting says 175x2@4ohms, 275x2@2ohms, and 550x1@4ohms. I want each speaker to get about 275 so how should I wire them?? It seems like every where I go tells me a different thing. Is there a way to wire the subs so that I use two channels, and each channel gets a 2 ohm load?
I think Ive got it, so I should wir3e the pos to the pos and the neg to the neg of one speaker, and then wire that speaker to, we'll say, the left channel, and then wire the pos to the pos and the neg to the neg of the othe speaker and then wire that to the right channel??
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
5
374
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
864
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
991
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
989
hogger
hogger
Murray, KY
bumpin_blazer
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
