hu cuts out front speakers at high volume
  • 4
Falcons
that **** i dont like
my friend just installed a hu in his 04 audi a4, and it cuts out the front speakers when they get even remotely loud (26/35 on the hu). we tried replacing this hu with another aftermarket unit and it is still having issues. i checked the ohm reading on the speakers and they read right around 4. what could be the problem? he is most likely going to just buy new speakers and amp them if we can figure out whats going on.
There may be a factory amplifier off the wiring harness that may be located in the rear of the car, or just behind the glove box..that will/could be your issue..id look further into that situation,of a stock amplifier implanted
what kind of door speakers are you running?
Try double-grounding the grounds coming out of the receiver. Make sure there are no frayed wires. Disconnect and reconnect battery. Make sure you are using high quality files for listening (not youtube rips).
Now my front right channel just died lol I just ordered the audio legion al110.4 I guess this is what happens when u use 20+ year old equipment
7
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
463
ringer ringer, chicken dinner... its your headunit. gotta upgrade mine as well, does the same thing, it cannot handle the additonal speakers, just...
Yeah I did remove the base cap and just straight wire you know grounded to amp and everything how it originally was before the base cap and it...
Falcons
Falcons
Albion, New York, United States
clickclickw00t
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
