Sub cuts out at high volume
  • 4
jaxfla83
CarAudio.com Newbie
I have 1 12 inch Memphis m5 with a jl audio 500 watt amp pushing it everytime I turn the volume up it hits but then starts going in an out I have it grounded straight to the body of my car with a 4 gauge pos an neg also have a 300 watt fuse even tried a capacitor but still did it. All set up as 1 ohm I even tested the amp with a multimeter an it never went below 14 volts. Any idea what's making it do that
Check your grounds! Both head unit and amp. I had this issue before and it was a grounding issue. Ground wire made enough contact to play low...
currently I am using 4g wires for my ground and power (1-1.5ft for ground and like 16ft for my power) and no I did not sand the area for the...
8
103
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
277
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
456
jaxfla83
CarAudio.com Newbie
jaxfla83
Kingsland
KicktheSDbasshead
Mr FaceCaser
    May 19, 2024
Mr FaceCaser
    May 19, 2024
