I have 2 12 in audiopipe eyecandy 1600 watt
ksabol
hey I have 2 12 in audiopipe eye candy subs, 1600 watt max. I had 2 12 inch kicker 03 cvr's that i sold to get these audiopipe subs, i was just wondering what everyone thinks about these subs and if they are any good or if i should just sell them. I have them hooked up to a 1500 watt audiopipe amp right now. any help would be awesome. Should i wait until the new Kicker Comp R comes out this year and get those to replace these or what?
This^^^. The eyecandy subs are not that bad, better than those kicks. But the sundowns would be much better, and as stated, a custom box would put them over the top. Great builders on here, a nutthug favorite is double 07, there is also ssteele and prorabbit, just to name a few.
Thanks guys! When I got the audiopipes my friends were bashing them and saying I was stupid to get them so I started overthinking everything lol im deff going to look into getting a custom box for them. My friend has a sundown 8 inch in his truck right now, thing smacks hard.
those audiopipes are not bad but if you want to move up from them i would suggest these subs, they are on presale now for $99 on 12's and these are very beefy subs, I myself is waiting for the 15's but if you are looking for a 12's this will be a good match and you can get an audiopipe 2k and these will still rock them
see info below
presale on Sub 12" 600watt $99
C2 Audio Threatcon-2
Specifications:
12" Threatcon-2 Subwoofer
600 Watts RMS
Available in Dual 4 Ohm and Dual 2 Ohm
Dual 2 Ohm: Threatcon-2 12d2
Dual 4 Ohm: Threatcon-2 12d4
3" Copper 4 Layer Voice Coil
Double Stacked 160 oz Magnet
High Current Flat Woven Tinsel Leads
Dual Spider Pack
Dual Stitched Non Pressed Paper Cone-
with Mid Excursion Foam Surround
Enclosure Recommendations:
Sealed: 1.0 - 1.25 ft^3
Ported: 1.5 - 2.0 ft^3 @ 35hzSealed: 2.0 - 2.50 ft^3
Ported: 3.0 - 4.0 ft^3 @ 35hz
T/S Parameters:
FS: 36.7HZ
VAS: 40.9 DM3
QES: .44
QTS: .40
BL: 16.8
MMS: 167.7G
SENS: 91.5 DB
XMAX: 28 MM
Woofer Dimensions:
EXT DIA: 12.48"
CUT OUT DIA: 11.18"
MOUNT DEPTH: 5.82"
What brands are offered in your location? Ive heard that Ground Zero and Stetsom are a great option and even Taramps
ksabol
ksabol
indiana
naughtyca
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
