i have a question?
  • 4
depends how you run the system. if you actually output 5kW, your power draw on the system is 6250W (assuming 80% efficiency) which relates to 425A at 14.7VDC at that output, your alt won't keep up and your voltage will drop to your battery voltage. as voltage drops, power output drops.
so with your plan, you'll never see the rated output of your amp since you can't maintain the supply voltage necessary. funny, eh?
What about the whole music doesn't use as much amps because it isn't steady. In my experience this has never been an exact science since so many variables come into play. What you're saying is all true I just want to point out that he might never need rated output.
LOL - mine was a higher end model too - iirc deh-9300. Low mileage too, it was sitting around for year collecting dust.
7
419
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
772
Nothing to add to this, Just wanted to say good luck and that I miss MiniDisc. OH!! Is that a Japanese Radio Tuner or does it get stations in the US?
aaronwhitlock3
Hodgenville, KY
i2ain2thunder
Decebal
    Jun 10, 2024
