I need advise, doing a big upgrade Infinity
  • 3
I have a buick 9 speaker car I want to upgrade from the factory speakers to infinity kappa speakers
5 1/4 x 2 pairs one pair conponent
6x9 one pair
3 1/2 center mount
Now I want the 5 1/4 speakers amped with the kappa four amp
But I also want to get the kappa one amp to run two 12 infinity kappa subs
I dont no which headunit I should get? Tell me your thoughts
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
186
You can just change the surround if the cone is not broken. This picture shows all the measurements you must make.
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
125
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
140
parkavenue
parkavenue
Manitoba, Canada
Dirtrider4eva
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
