I need help wiring my JL W6 V2's please
  • 1
joem1cha3l
They will be going to a 1200 watt amp. They are already mounted in the box and connected to terminal connectors on the outside of the box. Its going to a 1200/1 JBL GTO amp. Whats the best way to wire these from the terminal connectors on each side of the box?
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Is that 1000w max? Don't expect to be able to bridge a 1000w amp at 2 ohms and get 500w x 2ch. I'm pretty sure you can't with that amp, for...
joem1cha3l
joem1cha3l
Delray Beach, FL
joem1cha3l
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
