I need help?!?! Wiring problem!!
  • 6
Ghobbs48
I have 4 10" kicker solo baric subs that came out of a truck that my grand paw bought and there was also 2 Rockford fosgate 500m punch amps powering these subs. Both amps only have one channel and 3 of the subs are 4 ohm and one is 8 ohm. How do I wire this up. It sounded great before in the other truck but Its been so long since I unhooked them. The amp says 500 watts x 1 into 2 ohms. I'm not very good with all this stuff so I'm just confused. Someone please help me and ask me questions if u don't understand something. Thanks, Grady
Yea Iv been trying to look it up and they said it lowers the ohm resistance to 2.?? Something like that but I forgot. But they sounded great before and all four where working and a custom stereo place had hooked the stuff up in the truck before.
they just wired two in parallel to one amp, and the other two in parallel with the other amp.
the 8ohm sub just gets less power. in a common chamber box that means the 4 ohm sub(s) fights it. but it will still work.
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Is that 1000w max? Don't expect to be able to bridge a 1000w amp at 2 ohms and get 500w x 2ch. I'm pretty sure you can't with that amp, for...
Ghobbs48
Ghobbs48
San Antonio, Texas
mylows10
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
