I need some links
  • 3
So you have an 800 watt sub (1600 is a peak spec, ignore it) the SVR-10 - 800 RMS dual 2VC ohm wired in parallel for a 1 ohm load paired with an...
7
85
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
181
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
135
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
482
bud
bud
Louisville, Ky.
Randy Savage
Doxquzme
    May 19, 2024
Dylan27
    May 19, 2024
