i need to contact danny vance
  • 2
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
175
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
128
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
471
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
363
the brick
Brick The Enforcer
the brick
corbin, ky
melnlovr911
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
