I want SPL what subs should i get?
The L7s can get louder IF they are set up and powered right. The AQs can take more power daily and play lower for "hair tricks"
Kicker fanboy strikes again. Patently false. HDC's will wear L7's out.
I happen to know //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
There's ppl out there putting up some big numbers with square kickers. Just saying.... AQ is nothing special, Chinese made DD clones with inferior softparts. I'd expect if a Kicker spider failed they would at least honor their warranty..... that being said I wouldn't use either, but if you concentrate more in building a proper box, either should do about the same.
He did say SPL so yes a 50hz tune. For the simple fact of cone area// And Taylorfade Im NO fanboy. Just stating facts, the L7s do have a bit more CA and not a bad motor. The soft part are ****.
Idk, I am no fanboy, but both at the Kicker L7 rms, I would think it would be pretty close... so 750 rms to each sub. Of course the AQ is more rugged and can take more power, hell probably even sounds better, but as for numbers, I would think it would be close @ that amp power. Since the L7 has much more cone area.
I will go buy a lame *** L7 this week and put it against my HDC3 10. I promise that Kicker doesn't want any part of that AQ.
There is a guy in USACi "street beating" (30 second average on music) a 160 with a pair of HDC3 10's. You think an L7 can touch that? Because if it could even come close, he would be using them instead of the AQ's.
Have 2 10" D4 spl audio subs built by Corey Dean using sundown SA motors. One is missing the magnet boot, that's how he received the motor...
Spl mini bass meter barely used with cigarette lighter plug. Measure to 160 db. $125 shipped.
I mean if your wanting to go cheap and you like making things i guess you could always make your own , is all you really need is a DMM a...
Excellent place to get a Tuned enclosure with everything Precut and ready to put together with a Diagram of each sheet Marked. $190 bucks. All you...
15
3K
You're not going to know until you test with a meter. Typically even carpeting a box as opposed to painting is going to lose a few tenths.
trenthonda1
trenthonda1
Florida
tommyk90
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
