96civ 10+ year member
OK I'm starting to plan out a few things for a home audio setup I will make by the end of the summer.
The first question I have is about impedance with receivers. I see a lot of receivers with a spec list having the RMS wattage listed in 8 ohms, but nowhere does it mention the stable impedance. Can I just assume that it is 8 ohm stable or will I be able to go down to 4ohms? Maybe I'd have to ask the manufacturer of the receiver, but until then I'm asking the real professionals, you guys //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.
The second question I have is about amplifier gains. Say I get a receiver rated at 125wRMS x 6 @ 8ohms and I want to push a 8ohm speaker rated at 50wRMS. In most receivers, will I be able to set the gain for each individual channel or am I SOL at this point? IF I am SOL at this point, would it be practical to attach a resistor in series with the speaker so that the channel outputs 50wRMS at that specific resistance load?
This might be hard to follow, but any help is appreciated.
