Factory Amplified Impedance and Speakers
  • 2
noveske
CarAudio.com Newbie
Have a Toyota Tacoma with the JBL system.
I know the factory JBL speakers are around 2 Ω.
Is it the JBL amplifier that dictates the impedance requirement from the speakers?
So if I swap head units and leave in the JBL system, how would you select speakers?
I'm thinking since the JBL stuff remains, I'd stick to 2 Ω? Would I be correct to assume that?
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Then you need what I listed. You also need to find out if your Honda Element has an OEM amplifier or not. And if you have steering wheel controls...
6
956
noveske
CarAudio.com Newbie
noveske
Central PA
noveske
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
