In need of other peoples thoughts
  • 2
i got 2 t215 the new 2010s and two t1500bdcp amps one to each 15. with a extra kintec audio battery the khc2400 hooked up thought id be getting alot more bass than what im getting with all im running and im runing 2 and 0 gauge all the way threw the car. ive had a million systems and i seem like i can never get passed one level of bass. idk why the setup i have right now isnt just an epic mind blow. i could really use some other peoples opionis thank you.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
168
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
122
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
468
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
361
gamekiller7
gamekiller7
Montague, Michigan
Phoenix Risen
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
