Infiniti G37 Coupe Zenclosures Sealed Box
  • 2
slovell
SC
Should I use stuffing in this sealed box for two 10" speakers with 0.5 cu ft chambers? I'm using Dayton Audio RSS265HO-44 10" subs wired for 4 ohms and a Zapco ST-1650XM ll mono amp. I've got stuffing in there at present but I just can't seem to get it to sound right. Very strong low bass and very weak mid and upper bass. I was hesitant to put stuffing in there to start with as the chambers are so small and now I'm wondering if I did the right thing. I'm limited as to what box I can use in the G37 as the trunk is very small. The Dayton's specs say they'll work in this small 0.5 cu ft space. Where should I go from here? It just sounds pretty much like a one note wonder at present.
Definitely disconnect that stock subwoofer as they said could be causing issues with the signal sent to the other amplifier and subwoofers.
7
Yeah if you want to be loud and don't mind losing the back seat start looking into building a wall. B pillar wall. Gives you lots of room for...
6
896
I don't know, maybe two 12's and two 15s on a IB wall maybe? Lol!
790
slovell
slovell
SC
campgood
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
