Infiniti G37 Coupe Zenclosures Sealed Box
  • 2
slovell
SC
Should I use stuffing in this sealed box for two 10" speakers with 0.5 cu ft chambers? I'm using Dayton Audio RSS265HO-44 10" subs wired for 4 ohms and a Zapco ST-1650XM ll mono amp. I've got stuffing in there at present but I just can't seem to get it to sound right. Very strong low bass and very weak mid and upper bass. I was hesitant to put stuffing in there to start with as the chambers are so small and now I'm wondering if I did the right thing. I'm limited as to what box I can use in the G37 as the trunk is very small. The Dayton's specs say they'll work in this small 0.5 cu ft space. Where should I go from here? It just sounds pretty much like a one note wonder at present.
Definitely disconnect that stock subwoofer as they said could be causing issues with the signal sent to the other amplifier and subwoofers.
Yeah if you want to be loud and don't mind losing the back seat start looking into building a wall. B pillar wall. Gives you lots of room for...
968
I don't know, maybe two 12's and two 15s on a IB wall maybe? Lol!
846
slovell
slovell
SC
campgood
