Input voltage on jl audio slash
  • 3
heyhi1
nyc
If I change the input voltage from low to high on my amp should I raise the gains? I have a helix dsp . It sends out more than 2v so my input should be set on high. After I put it on high my volume was a lot lower
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
6
83
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
601
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do...
The ZVX 8 doesn’t do well sealed. 1.25 cubes ported 35-38 HZ is what it will like. Very inefficient 8 and wasn’t very impressive to me, even in a...
heyhi1
heyhi1
nyc
LosIsATool
RedRyder18
    May 11, 2024
RedRyder18
    May 11, 2024
