Install Head ache
  • 3
mattgxp
hello. I have lately been trying to install a kenwood double din head unit into my 04 bonneville gxp. I have the right wiring harness and antenna adapter and have gotten the head unit to power on. When the head unit is in standby mode it doesn't make any noise, as expected. However, when I put it on tuner (or any other mode) there is a high pitched loud static that comes out of the front left door and the rear door speakers - I do not know what is wrong. When I had first attempted to install the head unit I did it with an incorrect harness and heard a pop - I proceeded to change the blown audio fuse which gave me audio power back, but I wonder if maybe something else was blown during this. Any help is greatly appreciated
thanks
I have tried to alternate grounds and power - I had it spliced into the cigarette lighter which worked and I also tried running the power straight from the fuse box, which also worked -but both still had the high pitched loud static
Sounds like either a speaker wire shorting to ground or you damaged the head unit when you wired it wrong. Fuse opening won't always happen quick enough to save delicate semiconductors. If you switch the speaker wires from the malfunctioning channel to a different speaker what happens?
I hooked up a speaker I had laying around to the front left speaker wires and still got static...How do I tell if the speaker wire is "shorting to ground"
Pull the head unit out, and at the harness use a test light to check 12v, ground, and Accessory. If all three are good, you have probably...
7
Youll need a Honda Civic reverse radio wiring harness and 20 toyota radio wiring harness ...match colors of wires and shes ready to go...
Installing a Jensen CAR710W head unit in my sons 2013 Volkswagen Golf. No steering wheel controls. I purchased the XSVI-9003-NAV wiring harness...
mattgxp
mattgxp
Doon, Iowa
mattgxp
Decebal
    Jun 10, 2024
