Installation Headaches
  • Thread starter <Jeremy>
  • Start date
  • Replies 1
  • Views 1K
    Participant list
<Jeremy>
Guest
I've got a 79 blazer, and i'm trying to put a CD player in it, its had one in it before, so the dash has already been modified alittle bit. I cant get the cd player mounting kit to fit at all, and its drivin me crazy. Other then cuttin the dash out more then i already have too, is there anything I can do to make this thing fit? Its already been in there once before, but i hit a major pothole and it fell out. I cant get it to go back in like it should.
79 blazer does not require a dash kit. if the dash has all ready been cut the remove the cage form the radio, squeeze the cage from top to bottom and insert it then bend the tabs. if this doesnt work get out your air saw and get to cuttin'
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Hi, I have a 2015 Mercedes W205 with the standard audio 20 system, which is terrible to be honest. In my W204 it was really good even though I...
Generally you can still use the High Level inputs on most any amplifier to get it installed off the HU speaker wiring. Its a bit old school way of...
10
Guest
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
