Sub in Ford F250 Supercab?
  • 2
97_jeeper
Tulsa
Alright guys...need some help. I am not really big into the car audio stuff....however, I enjoy a nice sounding system. I have gone with an Eclipse desk, focal speakers and a Kicker 5 channel amp. The problem I am having now is the sub. What the heck should I go with? I don't have any room under the rear. I was considering the JL stealth box that goes in the center console. The **** part is...those things run about $500. Does anyone have any other suggestions? What about making a box for the console? Could that be done, instead of buying the JL box? Thanks for the help and any suggestions!
Brandon
As long as you have the know how and the patience a box could be built to go anywhere. shop for a woofer first though, something that performs well for the music you listen to in the air space you will be able to provide in the center console. Eclipse has some small box woofers, soundstream, kicker solo (power hungry) etc.
if this truck is a supercab why dont you put somthin under the rear seat? if that is not an option i do suggest makin a bow for the center console. it should work
I have a truck that I just built a great sub enclosure for. I did not want a huge sub box like you, just a nice sounding unit. The truck cab (Toyota Tundra) has Captains chairs with a console inbetween. I removed the console and built a box that runs between the two front seats and partially into the back 'extended' part of the cab. THat way it is out of the way all of the time. The bass response is very low and punchy, not boomy or one-noted.
The stock conole is too high to set on top of the sub box so I am going to get a smaller aftermarket one to replace it. Gotta have cup holders!
I used what is commonly referred to as a vented isobaric setup. It gives great bass response, though it costs more since it requires two speakers. However an isobaric system only requires a box 1/2 the normal size, which is what I was going for. Look into that option if you want a small enclosure.
I had a Dodge Ram and built subs that fit underneath the seats. However the boxes had to be smaller than what was required (sealed non-isobaric) and they had a nasty frequency response peak that took some serious crossover and EQ gymnastics to fix. Box size is very important for good sound.
If you want to talk more send me an e-mail at jroberts@satx.rr.com. I am just passing through this news group.
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
253
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
407
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
515
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
829
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
531
97_jeeper
97_jeeper
Tulsa
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
