cyberbob121
Hey guys,
I am new here, and I've hooked up a few systems but am definitely no expert, and for some reason I keep getting conflicting information.
Here is the gear I have to install in my boat:
(2) Wet Sounds XS-650's
Impedance: 4 ohms
RMS Watts: 100
PEAK Watts: 200
Frequency Response: 40Hz to 20Khz
Sensitivity: 90db at 1watt / 1meter
Mid Bass: 6.5 inch composite cone woofer with rubber surround.
High Frequency: Coaxially mounted Titanium Tweeter
(2) Kicker KMT674 Tower speakers
4-ohm impedance
power range: 5-150 watts RMS (300 watts peak power)
frequency response: 50-21,000 Hz
sensitivity: 93 dB
(1) Wet Sounds Syn4 Marine 800 watt Amp
RMS Power @ 4 ohms 125 watts x 4 channels
RMS Power @ 2 ohms 200 watts x 4 channels
Bridged RMS Power 400 watts x 2 channels
Amplifier Class Class H and Class G/H
Number of Channels 4
Total RMS Power Output 800 watts
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
(1) Kicker CVT 10" 4 Ohm sub
800 Max/400 RMS
I thought for sure I could only power the speakers with this amp but I have read others hooking up 6 speakers and 2 subs by running the speakers either parallel or in series. I really don't know anything about hooking up speakers in parallel or in series but can this amp power all of the speakers and the sub? Could it possibly power 2 more XS-650's? If not, what would you recommend?
Any help is greatly appreciated. I have heard this is a very powerful amp I just don't know how to bridge it to get what I'm looking for.
Sorry for the long read
Thanks
Impedance: 4 ohms
RMS Watts: 100
PEAK Watts: 200
4-ohm impedance
sensitivity: 93 dB
800 Max/400 RMS
Thanks
