Installed new system and need assistance
  • 3
okay so after scraping around in the my trunk panels i found a unit that i was hoping to be some sort of factory amplifier but unfortunately its a radio unit 4G0035056E, the harness looks very similar to the harness behind the media unit if I remember correctly, so i was hoping anyone could assist with a site or link where I can find out the wiring diagram of this unit/harness/
It would make life so much easy if I can just get a T harness to tap into these wire for the LOC of they are indeed speaker wires, possibly even power and ground as well
Okay so tested to pin for the LOC, i cant get any voltage on the speaker wires they connected to the LOC, still have not been able to get to the actual speaker wires seeing as im still waiting on the tool to remove the seat
Someone mentioned that the voltage from the speaker may be low voltage already and thus the LOC not working correctly, dont know how true that could be.
Going to see if i cant get a sound shop to tap into all 4 door speakers and run wires to the trunk for the LOC so its not under my seat anymore
If it was low voltage, it would only be able to power headphones. Only way I see this being plausible, is if the speakers have individual amplifiers mounted near them, and the installers spliced before the amp.
To test this theory, you could use a pair of female RCA adapters to wire from before that harness and into the RCA wires.
To test this theory, you could use a pair of female RCA adapters to wire from before that harness and into the RCA wires.View attachment 37600
I believe thats probably what the guys issue was seeing as he is referring to the wires going to his factory subwoofer so there must have been an amp there
thank you for the quick reply ,I contacted LordofBass and the part is backordered but I'm on a waiting list Cheers:)
The install looks very nice and clean for sure. Thanks for sharing the pics as well as your experiences
MarcelGous
CarAudio.com Newbie
MarcelGous
Cape Town, South Africa
1aespinoza
SPLBassJunkie
    May 21, 2024
Mr FaceCaser
    May 20, 2024
