installing kenwood ddx418 head unit
  • 3
I just got a kenwood ddx418 touch screen stereo. Its going in a 2004 grand prix. I have all the colors matched up but it wont power up. Theres a flashing red light on the front but the screen wont turn on. Ive tried a few different combinations of the wires. Theres a few wires I think could be the problem. Out of the stereo theres a blue wire, blue/white, orange/white, red, yellow, black. Out of the factory harness is all the same colors except there is a orange wire also. There is also a hot wire that was ran from my fuse box to the dash. Ive tried about everything and dont know what else to do. If anyone has suggestions what to try please let me know!
Red- acc on (ignition)
Yellow- 12v hot (constant)
Black-ground
Blue-pwr antenna
Blue/white-remote on (amp)
Orange/white-dimmer
use a dmm to find your hot and acc from the harness
the orange wire is an illumination wire. I use this one instead of the orange/white. On the vehicle the new wire running to the fuse panel is for your acc power. They rewired instead of using the module so the red wire on the interface harness wont be used. instead you hook up the red wire for then ew deck to the wire running to the fuse panel.
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
441
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do...
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
Tshaffe
Tshaffe
CrossoverOre
winkychevelle
    Jun 3, 2024
