INSTALLING STROBE LIGHTS???
davidrh7
Does anyone know how to install "in-headlights" strobes by APC? i get it but i have no clue about wiring and connecting it to switch and battery. I have a box with a red and black wire coming out of it and i have a switch. where do i connect the red and black wires? thats all i need. thanks.-David Henley dhen85@msn.comemail me here
if i remember right you hook the red wire to the batery or any power source and the black just needs to be grounded. then you also need a switch for tnem right? that just goes in eihter of the wires. just run one of them into a switch and it should work. well good luck
Well u drill the hole an everything in the headlight an install all of that. now for the wiring. take the black one an ground it out on the car. an take the red one an run it in to the car where ever u goin to put the switch ( u may need to buy more wire an connect the extra wire to what it comes with). the switch they send u is cheap i tried mines with it an it melted in the car cause it cant take the load so go down to an electronics store an buy some good switches. ok take the red an connect it to one side of the switch an run a wire from the positive side of the battery an run it to the other side of the switch an it should work.
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
491
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do...
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
davidrh7
davidrh7
Nashville, TN
Machiaivelli
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
