Installing system in my **** bus
damnbusdriver
I'm hoping someone can help me build my system? i'll run down all the components 1st.
I bought a pioneer head unit that has 3 rca's out, front, back and subs
From there I'm wanting to go into 2 pioneer gm-d9605 amps.
From there I have two jbl 6x9's for the front
four jbl 6 1/2's for the middle of the bus and two jbl single voice coil 12" subs for the bass in the back. These subs have a a switch so you can change them from 2 to 4 ohms
this is where I'm lost. should i use 1 amp for the front speakers and 1 sub? ! amp for 4 center speakers and 1 sub? should i use on amp just for the subs? Do i run two sets of wires to the subs or 1 set and hook them up to each other? All the ohms and bridging yada yada has me lost? Somebody ?
I'm hoping someone can help me build my system? i'll run down all the components 1st. I bought a pioneer head unit that has 3 rca's out, front, back and subs
depends on if u care about how loud speakers are in back we don't care about rear speakers.. if u gotta get pioneer i'd get the 4 channel for front speakers and the 1200d for subs (if u did each sub at 4 ohm that amp would do about 400rms per sub).. u can run 1 wire (i suggest 2 or 0 ga since u doing 2 amps) and then u use a fused dist block to run 2 smaller very short wires to each amp.. if u mean rcas i would run 2 sets if u can..
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
496
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
damnbusdriver
damnbusdriver
Beloit, WI
Jeffdachef
