Is 16AWG ok for 300 w RMS?
mdereske
Michigan
I have some left over 16AWG RF wire from running wires for my speakers, and was wondering if this would be OK for running a RE SR 10 at 300W rms? A lot of places online I checked out recommended 8-10 AWG. To me this seems like overkill. Will the 16 be ok, or should I go thicker?
Are you going to use the wire to run power to your amp? Or are you going to use it to run the signal from the output of the amp to the sub?
For power= NO
For signal=Just fine...
Would it work? Yes.
Should you probably go a bit bigger? Yes.
He's actually wrong.
It wouldn't work.
Doing the math using the 'watt formula' (w=v*a)
300=12*(a)
300/12 = A
25 = A
The maximum amperage a 16awg wire can take is 22 amps. If played for too long, the wire would get hot and catch on fire.
However, if you're running from the amp to the sub, your amplifier only puts out low amperes, but high volts.. and most wire can handle seemingly infinite amount of volts. So, you'll be fine if you're doing that.
i used 18 ga for 600 rms when i was mad young
and my power wire was 12 ga //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
it was quite fail, but i was young and thought i was cool, so w/e
i used 18 ga for 600 rms when i was mad youngand my power wire was 12 ga //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
12ga power wire.. Holy sh*t lol
I made a lot of money repairing fuse boxes that were destroyed from people taping into them. Pay once by doing it right. Do it wrong, the second...
14
724
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
570
This Is a NIB amplifier, one of two that I was to use. Decided to go class A/B on the front mids and tweets and just purchased a Helix B FOUR...
Good thing its under warranty and that you have contacted A.Control about the issue so it has been documented. It will help speed up the return...
6
mdereske
mdereske
Michigan
Brian_smith06
