is dual enclosure possible?
  • 4
basswiigee
MICHIGAN
now ive had 2 boxes in my trunk before and it didnt sound too bad at all, but could i put a sealed and a vented enclosure together in the same trunk, or would it totally cancel out and sound like garbage? oh and how do you tune a box or figure out the hertz?
What are you actually trying to accomplish exactly?
put four 12s in my car, and have it not sound bad, until i can save enough for what i want, heard vented is best for bass, cant fit a vent for four in my car, got a sealed box in there now, just thought it might work, can get vented box for cheap[prefab], but like i said it would be temp. and i was wondering about the tuning cuz i know nothing about it except the lower, the deeper and my radio has a bunch of presets for my subs, but i dont know if i should use it if i dont know how to tune it...
ok, thanks, no room or funds at the moment for custom, plus don't want a custom box for cheap subs, prefab single 4 enclosure? with two subs facing up and two front am i gonna have conflict? there are two prefabs that fit my car, 1 2up,2front, and 1 2front,2side, which do you think would be best considering im going prefab which ***** in itsself...
You would most likely sound louder and better with 2 good subs in a custom enclosure.
Enclosures aren't mega expensive either, I would think about a 4cf box would be $180-200
What's your budget?
yeah i know, but i already got the four 12s[3013ps], not worth building a box for, saving for 2 12xxx, then i'll customize, just looking for a cheap way to have some loud bass until then, i got two in there now, but not loud enough, just had 3 10's and 2 12s in there, atleast trying to get back to that level, the prefab box is 129.00, but i asked this question 2 see if i could just throw another box back there temp. and spend like 60 lol, but im not looking for no super sq, spl, just something that will pound hard...
What amp?
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
558
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
711
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
938
basswiigee
basswiigee
MICHIGAN
basswiigee
Decebal
    Jun 10, 2024
