Is it too much power or what
  • 2
jackheerer
I am planning on installing a pro-cast series mmats 15" sub, specs say it rms's at 700. store rep says it will hold more than this easily. Any other opinions.
I do not want to blow this speaker like I have cooked many rockfords from over powering them.
I will be running a RF BD1000.1 pussing 1000 watts @ 2 ohms.
Thanks for your opinions
Originally posted by jackheerer:I am planning on installing a pro-cast series mmats 15" sub, specs say it rms's at 700. store rep says it will hold more than this easily. Any other opinions.
It will handle it.
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
4K
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
4
I had 2 ab 15's in the same size sealed box (4cuft) and it was loud but these sql-15's are on whole different level 🤣
jackheerer
jackheerer
Columbus, Ga
ramos
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
