Is this Setup any Good????
  • 4
yroc434
Va
Ok here are some specs on my equipment:
Enclosure: Ported
Width: 38"
Height: 14"
Gross Airspace: 1.71 cu. ft. per chamber
Net Airspace 1.48 cu. ft. per chamber
Port: 12"x 1 1/4"x 19"
Port Volume: .23 cu. ft. per chamber
Subs: (2) 12" SWR 12D2 (wired @ 2ohms)
Frequency Response: 24-200hz
Power handling: 300-1000 watts rms/ sub
Sensitivity: 84db
Ported box: 1.25-1.50 cu. ft.
Amplifier: Hifonics BRX2000.1D
2 ohms 1400x1
LPF: 35-250hz
Subsonic Filter: 15-35hz
Frequency response: 10-250hz
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
811
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
yroc434
yroc434
Va
alfisti
