Is this setup good????????
Oh, then please suggest one with 40,000-45,000 INR
And yes, why didn't you suggest a prefab sub??? I can't make boxes to mount single woofers!![emoji26]
because they sound like ****. Just have someone make a sealed box according to specs on the web page for the sub you go with.... I know first hand how difficult It is to find someone who knows how to make good ported boxes.
HU: MVH-289BT - 6k
Front Speakers: TS-D1730C - 15k
Sub: TS-W1211D4 - 12k
Sub AMP: GM-D8601 - 15k
Total - 48k
Once again above prices are M.R.P and you should be able to source them for cheaper at your local shops. If you go with either of my subwoofer suggestions during installation you will tell the installer to wire the subwoofer in parallel. If he does not know what wiring in parallel means you will find another installer.
I highly suggest going with the 74k M.R.P setup you will be very satisfied with the same or going with the above setup but replacing the MVH-289BT Head Unit with the DEH-X6900BT Head Unit.
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
6
793
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
7
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
sn03
Master of WannaBe
sn03
Guwahati, India
Buick_66
