Is this speaker Busted?
  • 6
kylej
So one of my rear alpine type R 6.5" speakers has a strange noise at only 1 frequency. For those of you who like Gucci mane in the song "Party in the trap" when the bass get's high pitched the speaker makes a ripping sound, only when the volume is maxed before distortion. It is only in 1 out of 4 of the exact same speaker. No other song does it at any level.
was it doing it before on that note or you just noticed it? could be a faulty speaker, blown speakers generally make a weird noise on high bass notes.
I haven't taken it out, the rear deck of my 98' sentra is a bit of a pain to get to if I don't have too. I had just loaded up that song on my flash drive and went to see how to bass sounded on it. Polarity is fine I just double checked it. Wiring is a bit sketchy because, on that particular speaker I didn't realize crutchfield sent wiring harnesses with it; so I had stripped the wire and just wrapped it around. I was going to put a set of connectors on it but haven't found the time just yet. Could that be causing it? Factory Speaker wire btw.
Yes, that could be causing it. If you have a wire that is not making 100% good contact, certain frequencies may vibrate the wire loose and cause a distortion sound. I would start with crimping on the proper harness/connectors for a solid connection to the speaker. If the problem goes away, you know that was the culprit. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
562
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
475
637
546
kylej
kylej
Franklin, West Virginia, United States
blazeplacid
