Is this sub compatible with this amp?
  • 3
vblasi29
11
RI
I already have this amp:
Rockford Fosgate PRIME R1000-1D Class D Monoblock Amplifier
I did have a JL audio w1 hooked up to that amp but the JL crapped the bed. =[
I really just do not have good luck with JL's..don't ask me why..I do not know. So I am not planning on getting another one.
Is this sub compatible with the amp I have?
Rockford Fosgate P2D2-12 (P2D212) 12" Dual 2 ohm Punch Stage 2 Sub
I do not really know a thing about ohms and power handling..etc.
Getting another amp is not an option either so please do not advise me to do so. I just want another sub that will be pretty reliable and not breaking my bank.
I am so upset right now.. I cannot describe the horrible feeling when I am in my car and now listening to music with no sub. It really nauseates me.
for that amp i would get this C2 audio threatcon 2 for $129 if your running 2 subs dual voice coil 4 or if you are running just 1 sub american bass xfl, PSI PLATFORM 1, get dual voice coil 2 if you will only run 1 sub
pm me if you have any questions
ok..well I cannot become an overnight professional on this subject. Thats why I am turning to others for help and some advice. Anything involving electrical crap is just not my forte.
If the RMS for that amp says 1000 watts for 2 ohms and 500 watts for 4 ohms, does that mean the sub has to have at least that RMS too?
So if that RF sub says RMS; 400 watts and peak:800 watts at 2 ohms, then basically that amp will blow that sub as well?
Also, what exactly does it mean that the amp is monoblock?
224
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
550
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
581
vblasi29
vblasi29
RI
vblasi29
