Do I need a second battery?
Casb0n
My 2 year warranty battery lasted 3 years and finally died. I went to the auto parts store to get a new one, and the guy there saw my subwoofer power cable and told me that it would be a lot better on the electrical system if I got a battery to put in the back. I told him that I only had a 350 watt rms subwoofer amp with a 30 amp fuse and he still said I should get another battery. Does this sound correct? 30 amps is barely more than the cigarette lighter fuse...
By the way, my car has a 110 amp alternator I believe.
I have a 600 CCA, I believe. Its around what the stock battery was. I did see lights dimming a few days ago, but that was right before my battery died and apparently my whole electrical system was on my alternator because the battery wasn't holding charge (according to the auto part store guy). Also, my ground wire wasn't attached good at that point either.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
171
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
126
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
470
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
362
Casb0n
Casb0n
Chattanooga, Tennessee
LosIsATool
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
