Is this too much power for 2 way speaker?
  • 2
Originally posted by B&R Innovations Keep the gain down a bit from norm
and be sure your running a high pass
it should handel it fine
Well I'm worried because I blew my subs with the gain turned practically off (1/12 turn on) and the wattage wasn't even close to the rms for the subs ( sub rms 250watts each, fed them 75watts each). I'll turn the gain to its minimum hopefully they won't get damged.
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
3K
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
4
I had 2 ab 15's in the same size sealed box (4cuft) and it was loud but these sql-15's are on whole different level 🤣
joshpoints
joshpoints
San Ma Tonga Central, CA
joshpoints
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
