Is this wiring configuration correct?
  • 3
LongThrow
My Kickers be swaggin'
Making sure I'm doing this right.
Battery Positive Terminal > 4g fuse holder > 100 amp AGU fuse > 4g wire > 4g input to Distribution block > 2 8g outputs (Fused side A, 60 amp AGU fuse > 8g wire out to subwoofer amp) (Fused side B, 40 amp AGU fuse > 8g wire out to mids/highs amp)
To further clarify, I have a 4g fuse holder with a 100 amp fuse about 4 inches from the battery, this 4g wire runes to the trunk, I have it distributed to 2 seperate 8g outputs, one output fused at 60amps, this goes to my sub amp, rated 650w @ 2 ohms, it has an onboard fuse of 2x30 amps fuses. And the other 8g output which has a 40 amp fuse, goes to my mids/highs amp which has an onboard fuse of 2 20amp fuses.
i'd probably swap the AGU fusing out for midi ANL though. AGU fuses have issues with the solder joints giving way. fuse will still appear to be good but it isn't and you'll be scratching your head as to why you have no power.
i don't carry them at my store nor do i install them if someone brings me them and wants them installed. i explain why they're no good and show them what i have to offer.
Thanks, and yeah the agu fuse I used previously in my distro block was cutting power to my amps, and was actually shorting out. the little block terminal of the output side was loose, and was constantly losing contact. I replaced them, though.
I'd wire the SVC subs in series for an 8 ohm load. Wire the DVC subs coils in series for a 4 ohm load. Wire the 4 ohm and 8 ohm load in parallel...
4
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
206
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
618
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
653
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
651
LongThrow
LongThrow
Springfield, MO
LongThrow
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
